hm_entitiesassociatedbygroupsmark
Selects entities associated through groups.
hm_entitiesassociatedbygroupsmark entity_type input_mark_id output_mark_id ?group_mark_id? ?level?
HyperMesh Tcl Query Command
Selects entities associated to each other through groups.
- entity_type
- The type of entity to query. Valid values are nodes, elements and components (only elements in components are considered).
- input_mark_id
- The ID of the mark containing the input entities. Valid values are 1 and 2.
- output_mark_id
- The ID of the mark containing the isolated output entities which contains only nodes, elements and components. Valid values are 1 and 2.
- group_mark_id
- The ID of the mark containing the groups to consider for association. Valid values are 0 (default, meaning all groups), 1 and 2.
- level
- 0 - No level down
- Comps
- Elems
- Nodes
To find nodes, elems and comps associated to comps 1-5 by all groups:
*createmark comps 1 1-5
hm_entitiesassociatedbygroupsmark comps 1 2 0 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
