hm_getreferencedentitiesmark
Finds entities that are referenced by the entities on the specified mark.
hm_getreferencedentitiesmark entity_type mark_id reference_flag output_mark_id string_array number_of_strings
HyperMesh Tcl Query Command
Finds entities that are referenced by the entities on the specified mark. This includes collected references, data name references and attribute entity references. Each type of entity that is referenced by the specified input entities is returned in a list, and the found entities are placed on the specified mark for those entity types. See the list of supported entities for hm_getreferencedentities.
- entity_type
- The type of entity to query.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- reference_flag
- The type of referenced entities to find. Bit values are used and the value is
calculated as (Bit0 + 2*Bit1 + 4*Bit2).
- Bit0
- 0 - Do not consider collected entity references.
- Bit1
- 0 - Do not consider data name entity references.
- Bit2
- 0 - Do not consider attribute entity references.
- output_mark_id
- The ID of the mark to place the found referenced entities on. Valid values are 1 and 2.
- string_array
- Reserved for future use. Must be set to 0.
- number_of_strings
Examples
To get all entities referenced by components with IDs 100-110 on mark 1 and highlight them on the screen:
*createmark comps 2 100-110
foreach entity_type [hm_getreferencedentitiesmark comps 2 7 1 0 0 -byid] {
hm_highlightmark $entity_type 1 h
To get only collected entity references for components with IDs 100-110 on mark 2:
*createmark comps 1 100-110
hm_getreferencedentitiesmark comps 1 1 2 0 0 -byid
To get only data name entity references for components with IDs 100-110 on mark 1:
hm_getreferencedentitiesmark comps 2 2 1 0 0 -byid
To get only attribute entity references for components with IDs 100-110 on mark 1:
hm_getreferencedentitiesmark comps 2 4 1 0 0 -byid
# Handle error
}Version History
11.0
