hm_attributeidfromname
Returns an attribute ID from the attribute name for the current template.
hm_attributeidfromname attribute_name
HyperMesh Tcl Query Command
Returns an attribute ID from the attribute name for the current template. If the attribute does not exist in the current template, an error is returned.
- attribute_name
- The name of the attribute to query.
To get the attribute ID of the OptiStruct PSHELL_T attribute:
hm_attributeidfromname PSHELL_T
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10-SA1-110
