hm_exportentitydefaults
Exports the entity default setting values to an XML file in the current working directory.
HyperMesh Tcl Query Command
Exports the entity default setting values, mandatory values, show/hide values, and so on, to the file EntityDefaults.xml, located in the current working directory: …\<currentWorkingDirectory>\HyperWorksDefaults\EntityDefaults.xml.
To export the entity default values currently defined in the Entity
Defaults
dialog:
hm_exportentitydefaultsErrors
None.
Version History
2021.2
