hm_aic_getcurrentclassifier
Returns the current classifier in the project directory set for classification process.
HyperMesh Tcl Query Command
Returns the classifier name/folder in the project directory set for classification process. This folder contains the respective labeling and training information. The current classifier folder is located in the project directory.
Examples
To get the classifier set for classification
process:
set cl_name [ hm_aic_getcurrentclassifier ]Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2025
