hm_getcrossreferencedentitiesmark
Finds entities that reference the entities on the specified mark.
hm_getcrossreferencedentitiesmark entity_type mark_id reference_flag output_mark_id string_array number_of_strings ?exclude_regions"
HyperMesh Tcl Query Command
Finds entities that reference the entities on the specified mark. This includes collected references, data name references and attribute entity references. Each type of entity that references the specified input entities is returned in a list, and the found entities are then placed on the specified mark for those entity types. See the list of supported entities for hm_getcrossreferencedentities.
- entity_type
- The type of entity to query.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- reference_flag
- The type of cross-reference entities to find. Bit values are used and the value is
calculated as (Bit0 + 2*Bit1 + 4*Bit2).
- Bit0
- 0 - Do not consider collected entity cross-references.
- Bit1
- 0 - Do not consider data name entity cross-references.
- Bit2
- 0 - Do not consider attribute entity cross-references.
- output_mark_id
- The ID of the mark to place the found cross-referenced entities on. Valid values are 1 and 2.
- string_array
- Reserved for future use. Must be set to 0.
- number_of_strings
- exclude_regions
- 0 - Include region entities in the search (default).
Examples
To get all entities that cross-reference components 100-110 on mark 1 and highlight them on
the screen:
*createmark comps 2 100-110
foreach entity_type [hm_getcrossreferencedentitiesmark comps 2 7 1 0 0 -byid] {
hm_highlightmark $entity_type 1 h
}To get only collected entity cross-references for components with IDs 100-110 on mark
2:
*createmark comps 1 100-110
hm_getcrossreferencedentitiesmark comps 1 1 2 0 0 -byidTo get only data name entity cross-references for components with IDs 100-110 on mark
1:
hm_getcrossreferencedentitiesmark 2 100 2 1 0 0 -byidTo get only attribute entity cross-references for components with IDs 100-110 on mark
1:
hm_getcrossreferencedentitiesmark comps 2 4 1 0 0 -byidErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
2019 - Added new optional argument exclude_regions.
