hm_getoffsetZ0
Returns the offset Z0 value of the specified element.
hm_getoffsetZ0 elem_id
HyperMesh Tcl Query Command
This command returns the offset Z0 value of the specified element.
- elem_id
- The ID of the element to query.
hm_getoffsetZ0 100
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
