hm_comparewritefile
Writes the current comparison data to a file.
hm_comparewritefile filename
HyperMesh Tcl Query Command
Writes the current comparison data (transformations, match types, match entities, etc.) to a file. This must be preceded by a call to a relevant hm_compareentities* command.
This file can be reloaded using hm_comparereadfile to repopulate the results in a different HyperMesh session.
- filename
- The full name and path of the file to write the data to.
To write the comparison data file to C:/temp/my_compare.txt for the same side comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiessameside surfs 1 surfs 2 0.1 2 0
hm_comparewritefile C:/temp/my_compare.txt
hm_compareend
To read the comparison data file from C:/temp/my_compare.txt and review the distances:
hm_compareinit
hm_comparereadfile C:/temp/my_compare.txt 1
hm_comparefinddistances 1.0 1
hm_comparesetreview 2
hm_compareend
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0
