hm_gettotalmoi
Returns the total tensorial moment-of-inertia values of the model about the center of gravity.
hm_gettotalmoi
HyperMesh Tcl Query Command
Returns the total tensorial moment-of-inertia values of the model about the center of gravity in the following order: Ixx, Iyy, Izz, Ixy, Ixz, Iyz.
Examples
To get the model tensorial moment-of-inertia:
set totalmoi [hm_gettotalmoi]
set IXX_model [lindex $totalmoi 0]
set IYY_model [lindex $totalmoi 1]
set IZZ_model [lindex $totalmoi 2]
set IXY_model [lindex $totalmoi 3]
set IXZ_model [lindex $totalmoi 4]
set IYZ_model [lindex $totalmoi 5]
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.2
