hm_exportplyorientation
Writes the fiber orientation vector for each element in a ply to a text file.
hm_exportplyorientation mark_id filename
HyperMesh Tcl Query Command
- mark_id
- The ID of the mark containing the plies to write. Valid values are 1 and 2.
- filename
- The full path and filename of the text file.
Examples
To write the fiber orientation vector for elements in all plies:
*createmark 1 plys all
hm_exportplyorientation 1 "C:/temp/drape.txt"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
