hwct_getinfofromlibrary
Query information from a currently connected library.
hwct_getinfofromlibrary entity_type mark_id attribute_list ?childgroupname=<value>? ?childkey=<value>? ?filter=<value>?
HyperMesh Tcl Query Command
- entity_type
- The type of connected library. Currently only supported for subsystems.
- mark_id
- The ID of the mark of entities. Valid values are 1 and 2.
- attribute_list
- The list of attributes, separated by semi-colons (for example, {attribute1; attribute2; ...; attributeN}).
- childgroupname=<value>
- The group name of the children on which the attribute information is needed.
- childkey=<value>
- The returned information is grouped by this key attribute on the child.
- filter=<value>
- all - Process all children of the given childgroupname for the input entities
Examples
Query the library for subsystem 2 and list it as per the childkey (hwrepalis). The child here is crash for subsystem 2:
{ 2 { crash { smd_cid : 6932c5faac1cc748a333bf0c49fb2f61 } }
*createmark subsystems 1 2
set library_info [hwct_getinfofromlibrary subsystems 1 id childgroupname=representations childkey=hwrepalias filter=retrieved]Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
