hm_postcardeditorformarkmask
Posts a card editor for a mark of entities.
hm_postcardeditorformarkmask entity_type mark_id ?title?
HyperMesh Tcl Query Command
This command posts a card editor for a mark of entities.
- entity_type
- The type of entity to post the card editor for.
- mark_id
- The ID of the mark containing the entities to post the card editor for. Valid values are 1 and 2.
- title
- Specifies the title of the card editor dialog. The default title is “Edit <entity_type>”.
To display a card editor for components with IDs 1-5:
*createmark comps 2 1-5
hm_postcardeditorformarkmask comps 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
