hm_getidpools
Returns a list of pool IDs or names for the specified entity type.
hm_getidpools entity_type ?return_type?
HyperMesh Tcl Query Command
Returns a list of pool IDs or names for the specified entity type. The pool IDs and names are returned in the same order.
- entity_type
- The type of entity to query.
- return_type (optional)
- Argument that specifies whether to return pool IDs or names. Valid values are name and ID (default if not specified).
Examples
To get the pool ID list for elements:
hm_getidpools elems
or
hm_getidpools elems idTo get the pool name list for
properties:
hm_getidpools props nameErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
