hm_me_occrepkeyget
Returns the representation key of a part occurrence.
hm_me_occrepkeyget part_idType
HyperWorks Tcl Query Command
Returns the representation key of a part occurrence. A part occurrence should be given.
- part_id
- The ID of a part or part assembly from which to retrieve the representation key.
To retrieve the representation key from part ID
5:
hm_me_occrepkeyget 5Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
