hm_getmarkall
Returns a list of lists containing the populated entity type and entity IDs for the specified mark.
hm_getmarkall mark_id ?model_name?
HyperMesh Tcl Query Command
specified mark. The first value in each returned list is the entity type, and the remaining
values are the entity IDs of that type. For example, if mark 1 is populated with elements
1-5 and comps 101-105, the returned values would
be:
{elems 1 2 3 4 5} {comps 101 102 103 104 105}Inputs
- mark_id
- The ID of the mark to query. Valid values are 1 and 2.
- model_name
- The optional model to get all marks for. If not specified, the current model is used.
To find all of the entities on mark 1:
hm_getmarkall 1To find all of the entities on mark 1 for model
model-2:
hm_getmarkall 1 model-2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
2020 - Added new option model_name.
