hm_markclearall
Clear all entity IDs for all entity types from the specified mark.
hm_markclearall mark_id ?model_name?
HyperMesh Tcl Query Command
This command clears all entity IDs for all entity types from the specified mark.
- mark_id
- The ID of the mark. Valid values are 1 and 2.
- model_name
- The optional model to clear all marks from. If not specified, the current model is used.
To clear the contents of mark 2 for all entity
types:
hm_markclearall 2To clear the contents of mark 2 for all entity types for model
model-2:
hm_markclearall 2 model-2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
2020 - Added new option model_name.
