hm_solverconvert
Converts a model from one solver to another.
hm_solverconvert source_solver destination_solver source_type destination_type batch
HyperMesh Tcl Modify Command
This command converts a model from one solver to another.
Supported solvers are:
| Solver Name | Solver ID | Solver Type |
| Nastran | 1 | |
| OptiStruct | 1 | |
| Abaqus | 2 | Standard2D, Standard3D |
| ANSYS | 8 | |
| LS-DYNA | 9 | Keyword971, Keyword970 |
| PAM-CRASH | 18 | Pamcrash2G2008, Pamcrash2G2007, Pamcrash2G2006 Pamcrash2G2005, Pamcrash2G2004 |
| Radioss | 20 | Block110, Block100, Block90, Block51, Block44 |
Supported conversions are:
| Source Solver Name | Destination Solver Name |
| Abaqus | Nastran/OptiStruct |
| ANSYS | Nastran/OptiStruct |
| LS-DYNA | Nastran/OptiStruct |
| Radioss | PAM-CRASH |
| PAM-CRASH | Radioss |
| Nastran/OptiStruct | Abaqus |
| Nastran/OptiStruct | Ansys |
| Nastran/OptiStruct | LS-DYNA |
| Nastran/OptiStruct | Radioss |
| ANSYS | Abaqus |
- source_solver
- The source solver name or ID.
- destination_solver
- The destination solver name or ID.
- source_type
- The source solver template type.
- destination_type
- The destination solver template type.
- batch
- Flag that indicates if the conversion should be run in batch mode.
Examples
Convert Abaqus Standard3D model to OptiStruct in batch
mode:
hm_solverconvert Abaqus OptiStruct Standard3D "" 1or
hm_solverconvert 2 1 Standard3D "" 1Convert Radioss Block90 model to PAM-CRASH Pamcrash2G2007 without batch
mode:
hm_solverconvert RadiossBlock Pamcrash Block90 Pamcrash2G2007 0or
hm_solverconvert 20 18 Block90 Pamcrash2G2007 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.101
