hm_getboundingbox_predefined
Returns the bounding box for a predefined box trim cut.
hm_getboundingbox_predefined mark_id predefinedcut limit
HyperMesh Tcl Query Command
This command returns the six values defining the bounding box for a mark of elements for a predefined box trim cut.
x_min y_min z_min x_max y_max z_max
The box values are determined depending on the following options.
- mark_id
- The ID of the mark containing the elements. Valid values are 1 and 2.
- predefined_cut
- The name of a predefined cut. Valid values are:
- front
- rear
- right
- left
- frontright
- frontleft
- rearright
- rearleft
- limit
- The x value of the box for predefined cuts front, rear, frontright, frontleft, rearright and rearleft.
To get the bounding box for the displayed elements using a front cut with a limit of 0.1:
*createmark elems 1 displayed
hm_getboundingbox_predefined 1 "front" 0.1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.130
