hm_getelemchecksummary3d
Returns the 3D solid element quality summary.
hm_getelemchecksummary3d mark_id options
HyperMesh Tcl Query Command
This command returns the element quality summary for the selected 3D elements. The return
values are grouped into 3 parts:
- The number of counted elements.
- The number elements that failed passing the selected measurement(s).
- A summary of the selected quality measurements. For every quality measurement, it
includes three items:
- The name of the quality measurement.
- The number of elements that failed passing this measurement.
- The quality value of the worst element using this measurement.
- mark_id
- The ID of the mark containing the elements to query.
- option
- This parameter constructs a table of quality measurements that are used to determine the summary. Each measurement includes the measurement name, failed value and solver ID (currently only HyperMesh solver ID = 0 is supported). Valid quality measurements include:
For every item, you can chose to only input the name and some values; in this case, the remainder will use the default values.
To count the displayed elements with tet_collapse ≤ 0.01 and vol_skew ≥
0.90:
*createmark elems 1 displayed
set table "tet_collapse 0.01 vol_skew 0.90"
set elem_sum [hm_getelemchecksummary3d 1 $table]Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
2019 - Added new option strings ortho_3d and size_ratio_3d.
