hm_comparegettransformationmatchcount
Returns the number of matches for a specific transformation.
hm_comparegettransformationmatchcount transformation_index
HyperMesh Tcl Query Command
Returns the number of matches for a specific transformation. This must be preceded by a call to a relevant hm_compareentities* command.
- transformation_index
- The index of the transformation to query, starting with 0. The number of transformations can be found using hm_comparegettransformationcount.
To find the number of matches for transformation 0 for the recursive comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiesrecursive surfs 1 surfs 2 0.1 2 0
set num_matches [hm_comparegettransformationmatchcount 0]
hm_compareend
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0
