hm_holedetectiongetmatedetails
Returns details about a specific hole/tube mating 'group'.
hm_holedetectiongetmatedetails index
HyperMesh Tcl Query Command
Returns details about a specific hole/tube mating 'group'. This must be preceded by a call to hm_holedetectionfindmates.
- index
- The index of the mate to get details for, starting from 0 up to the number of found mating groups minus 1.
To write out all geometric shell mate details to a file named C:/temp/holes.txt:
set holesfile [open "C:/temp/holes.txt" "w"]
hm_holedetectioninit
*createmark surfs 1 all
hm_holedetectionsetentities surfs 1
hm_holedetectionsetholeparams hole_shape=31
hm_holedetectionfindholes 1
set n [hm_holedetectiongetnumberofmates]
if { $n > 0 } {
puts $holesfile "Number of mates = $n"
puts $holesfile "Mate details"
for {set i 0} {$i < $n} {incr i} {
puts $holesfile "i = $i [hm_holedetectiongetmatedetails $i]"
} else {
puts $holesfile "Holes mates not detected."
hm_holedetectionend
close $holesfile
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
