hm_jobs_removeServer
Removes a server.
hm_jobs_removeServer name
HyperMesh Tcl Query Command
This command is used remove a server. The same information will be removed from the server config file.
- name
- The name of the server to be removed.
To remove the server named HWUL:
hm_jobs_removeServer HWUL
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
