hm_getsurfaceuvatcoordinate
Returns the nearest surface u,v coordinate from a given x, y, z location.
hm_getsurfaceuvatcoordinate surface_id x y z
HyperMesh Tcl Query Command
The coordinate is projected to the nearest point on the input surface and returns its
normalized u, v coordinates, the coordinates of the projected point and a string specifying
the position of the projected point on the surface. The returned string can be one of:
- Point snapped to Edge
- Point snapped to Edge End
- Point snapped to Edge Start
- Point snapped interior to the Surface
- Point snapped to Vertex
- surface_id
- The ID of the surface to query.
- x
- The x coordinate of the point.
- y
- The y coordinate of the point.
- z
- The z coordinate of the point.
Examples
To query the u,v coordinate of the point (1702.4653, 403.6108, 777.5562) projected on
surface
26:
hm_getsurfaceuvatcoordinate 26 1702.4653 403.6108 777.5562Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
