hm_nodeismidnode
Checks if a node is a mid-side node.
hm_nodeismidnode node_id
HyperMesh Tcl Query Command
Checks if a node is a mid-side node on a second-order element. Returns 1 for a mid-side node, 0 otherwise.
- node_id
- The ID of the node to check.
Examples
To check if node ID 99 is a mid-side node:
hm_nodeismidnode 99
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.2
