hm_gethmfileversion
Returns the binary file version string for a specified HyperMesh database.
hm_gethmfileversion filename
HyperMesh Tcl Query Command
Returns the binary file version string for a specified HyperMesh database. The string is comprised of 2 parts, major-minor, where:
- major is the major file version. It is itself comprised of two parts, release.binary.
- minor is the minor file version.
For example: 13.02-110
- filename
- The full path and filename of the database file. Paths with spaces must be enclosed in quotes.
To get the file version for
C:\temp\test.hm:
hm_gethmfileversion C:/temp/test.hmErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0.110
