hm_ce_imprintelemsget
Returns imprinted elements for a connector.
hm_ce_imprintelemsget id reserved
HyperMesh Tcl Query Command
- id
- The ID of the connector to query.
- reserved
- Reserved for future use, must be set to 0.
Examples
To get imprinted elements from the connector with ID 101:
set imprinted_elems [hm_ce_imprintelemsget 101 0]
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
