hm_getshelloverlapinfo
Returns information regarding proximity overlap between a selection of components or elements.
hm_getshelloverlapinfo source_entity_type source_mark_id target_entity_type target_mark_id maximumproximitydistance
HyperMesh Tcl Query Command
elements. The command returns the proximity overlap area, the overlap volume, the maximum
and minimum proximity distance, the coordinates of the overlapping bounding box corners in
the global system, the origin of the bounding box, and its x, y, z vectors from the origin
in the following
format:
<proximity_area> <proximity_volume> <max_proximity_distance> <min_proximity_distance> (Bounding Box info){{MinPointX MinPointY MinPointZ} {MaxPointX MaxPointY MaxPointZ}} (PCA Box info){{OriginX OriginY OriginZ} {XVectorX XVectorY XVectorZ} {YVectorX YVectorY YVectorZ} {ZVectorX ZVectorY ZVectorZ}}Inputs
- source_entity_type
- The type of source entity. Currently supported for components and elements.
- source_mark_id
- The ID of the mark containing the source entities. Valid values are 1 and 2.
- target_entity_type
- The type of target entity. Currently supported for components and elements.
- target_mark_id
- The ID of the mark containing the target entities. Valid values are 1 and 2.
- maxproximitydistance
- Maximum proximity distance below which the overlap is calculated.
Examples
To get overlap information between component 7100314 and component 7100361 for a proximity
distance of 5.0:
*createmark comps 1 7100314
*createmark comps 2 7100361
hm_getshelloverlapinfo comps 1 comps 2 5.0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.2
