hm_writemeshcontroltemplate
Writes out the Mesh Control template file.
hm_writemeshcontroltemplate filename
HyperMesh Tcl Query Command
Writes out the Mesh Controls template file. This is an XML formatted file. This contains all of the mesh control information, except for the entity selection.
- filename
- The full name and path of the file to write.
To write out the file to C:/temp/meshcontrol.xml:
hm_writemeshcontroltemplate C:/temp/meshcontrol.xml
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
