hm_gethmfileuserprofile
Returns the user profile information saved in the HyperMesh database.
hm_gethmfileuserprofile filename
HyperMesh Tcl Query Command
Returns the user profile information saved in the specified HyperMesh database. The string is comprised of 3 parts, application, profile and subprofile. For example: HyperMesh RadiossBlock Block140
- filename
- The full path and filename of the database file. Paths with spaces must be enclosed in quotes.
To get the user profile for C:\temp\test.hm:
hm_gethmfileuserprofile C:/temp/test.hm
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
