hm_ce_getlinkinfo
Returns link info for a connector including entity type, IDs/names, locator rule and XYZs.
hm_ce_getlinkinfo id index
HyperMesh Tcl Query Command
- id
- The ID of the connector to query.
- index
- The index of the link on the connector.
To get link information for connector ID 1 for all links:
set ce_id 1
set num_ents [hm_ce_numlinkentities $ce_id]
for {set count 0} {$count <= $num_ents} {incr count} {
foreach {type info state rule} [hm_ce_getlinkinfo $ce_id $count] {
lappend linkArray($type) $info
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10-SA1-120
