hm_getlockedentities
Queries entity locks.
hm_getlockedentities entity_type dataname
HyperMesh Tcl Query Command
This command returns locked entity IDs across all submodels.
- entity_type
- The type of entity to query locks for.
- data_name
- The data name to query locks for. Currently only supported for "id".
To query ID locks for all elements:
hm_getlockedentities elems id
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
