hm_setmodelcheckcheckstatus
Sets the run status for the specified Model Check check display name.
hm_setmodelcheckcheckstatus display_name status
HyperMesh Tcl GUI Command
- display_name
- The check display name.
- status
- 0 - Not run
- 1- Run and found failed entities
- 2 -Run and found no failed entities
- 3 - No relevant entities found in the model
To set the run status for the check named "Unused Materials" to run (1):
hm_setmodelcheckcheckstatus "Unused Materials" 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.101
2019 - Added new status value 3.
