hm_getunmeshedsurfstomark
Places the unmeshed surfaces from the input mark onto the output mark.
hm_getunmeshedsurfstomark output_mark_idinput_mark_id
HyperMesh Tcl Query Command
- input_mark_id
- The ID of the mark containing the input surfaces to consider. Valid values are 1 and 2.
- output_mark_id
- The ID of the mark containing the unmeshed surfaces. Valid values are 1 and 2.
Examples
To find the unmeshed surfaces from component with ID 200 and place them on mark 2:
*createmark surfaces 1 "by collector id" 200
hm_getunmeshedsurfstomark 1 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
