hm_getinputoffsetid
Returns the current import offset ID value for the specified entity type.
hm_getinputoffsetid entity_type
HyperMesh Tcl Query Command
Returns the current value of the import offset specified with *feinputoffsetid.
- entity_type
- The type of entity to query.
To get the offset value for elements:
hm_getinputoffsetid elemsErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
