hm_getsolidshelloverlapinfo
Returns information regarding proximity overlap between one/more solid cavity element(s) and structural components.
hm_getsolidshelloverlapinfo source_entity_type source_mark_id target_entity_type target_mark_id maxproximitydistance
HyperMesh Tcl Query Command
Returns information regarding proximity overlap between one or more solid cavity elements
and structural components (2D mesh). For each cavity (source components), the command
returns the cavity surface area, the cavity volume, and the proximity overlap area per
structural component (target components) in the following
format:
{<solid1_compid> <solid1_surfacearea> < solid1_volume> {{<overlapshell1_compid> <proximity_area_with solid1>} {<overlapshell2_compid> <proximity_area_with solid1>}}}Inputs
- source_entity_type
- The type of source entity. Currently supported for components. Only 3D elements are considered.
- source_mark_id
- The ID of the mark containing the source entities. Valid values are 1 and 2.
- target_entity_type
- The type of target entity. Currently supported for components. Only 2D elements are considered.
- target_mark_id
- The ID of the mark containing the target entities. Valid values are 1 and 2.
- maxproximitydistance
- Maximum proximity distance below which the overlap is calculated.
Examples
To get overlap information between component 20 and components 2, 10, and 13 for a
proximity distance of 5.0:
*createmark comps 1 20
*createmark comps 2 2 10 13
hm_getsolidshelloverlapinfo comps 1 comps 2 5.0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.2
