hm_historyscriptunsupportedtofile
Writes out to files a summary of the unsupported commands contained inside .tcl script files.
hm_historyscriptunsupportedtofile input_file output_dir
HyperMesh Tcl Query Command
Writes out to files a summary of the unsupported commands contained inside .tcl script files. An individual file or an entire directory (including its children) can be specified.
The output files have the same name as the input .tcl files but with a .txt extension, and are written with the same directory structure as the input files.
- input_file
- The full name and path of the input .tcl file, or input directory.
- output_dir
- The full path of the directory where the output files will be written.
Examples
To write out the list of unsupported commands for test.tcl in C:\temp to C:\output:
hm_historyscriptunsupportedtofile C:/temp/test.tcl C:/output
To write out the list of unsupported commands for all .tcl files in C:\temp to C:\output:
hm_historyscriptunsupportedtofile C:/temp C:/output
# Handle error
}Version History
14.0
