hm_ce_getrealizedtestpoints
Gets the realized test points from the connector.
hm_ce_getrealizedtestpoints connector_id
HyperMesh Tcl Query Command
- connector_id
- The ID of the connector.
Examples
To get the realized test points location from the connector:
set ce_id [ hm_latestentityid connectors ]
set realized_pt_cords [ hm_ce_getrealizedtestpoints $ce_id]
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022
