hm_getcentroid
Returns the geometric centroid for selected entities.
hm_getcentroid entity_type mark_id
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query. Valid values are surfaces, solids and nodes.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
To get the centroid of all surfaces:
*createmark surfs 1 all
hm_getcentroid surfs 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
2022 – Added nodes to the list of supported entity types.
