hm_compareentities
Generates comparison results for entities positioned at any location.
hm_compareentities source_entity_type source_mark_id target_entity_type target_mark_id tolerance ?result_type? ?review_results?
HyperMesh Tcl Query Command
Generates comparison results for entities positioned at any location. A maximum of one match is found for each source entity. This must be preceded by a call to hm_compareinit.
These results can then be queried using hm_compareget* APIs, or written to a file using hm_comparewrite* APIs.
- source_entity_type
- The type of source entity. Valid values are surfs only.
- source_mark_id
- The ID of the mark containing the source entities. Valid values are 1 and 2.
- target_entity_type
- The type of target entity. Valid values are surfs only.
- target_mark_id
- The ID of the mark containing the target entities. Valid values are 1 and 2.
- tolerance
- The tolerance value to use for the comparison.
- result_type
SURFS to SURFS 0 - Basic Matched (paired) Unmatched 1 - Full (default) Matched (paired) Overlapped Intersected Unmatched 2 - Detailed Matched (paired) Overlapped (paired) Intersected (paired) Unmatched - review_results
- 0 - Do not automatically show the graphical comparison results after execution.
To write the detailed comparison results file to
C:/temp/my_compare.txt for the general comparison of surfs 1-20 and
101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentities surfs 1 surfs 2 0.1 2 0
hm_comparewriteresults C:/temp/my_compare.txt
hm_compareendErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0
