hm_getmodelcheckcorrectiondisplayname
Returns the correction names for a given check.
hm_getmodelcheckcorrectiondisplayname check_display_name
HyperMesh Tcl Query Command
- check_display_name
- The GUI display name of the check. This is case sensitive.
Examples
To get the correction names for the "Unused materials" check:
hm_getmodelcheckcorrectiondisplayname "Unused Materials"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
