hm_ishistorysupported
Returns the history support level for the specified command.
hm_ishistorysupported command
HyperMesh Tcl Query Command
Returns the history support level for the specified command. The return values are as
follows:
- -1 - Command does not modify the database and therefore does not affect history
- 0 - Command is not supported for history
- 1 - Command is supported for history
- command
- The name of the HyperMesh Tcl Modify Command command to query.
To query the support level of *displaynone:
hm_ishistorysupported *displaynone
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
