hm_ce_linkprojectionorderget
Returns ordered projection information from links of spot connectors.
hm_ce_linkprojectionorderget mark_or_id option flag
HyperMesh Tcl Query Command
- mark_or_id
- The mark ID or connector ID to query.
- option
- 0 - Return stored projection information with spot connector(s)
- flag
- id - mark_or_id is an ID
Examples
To get projection information from spot connector of ID 101:
set proj_infos [hm_ce_linkprojectionorderget 101 1 id]
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
