hm_getreferencedentities
Finds entities that are referenced by the specified entity.
hm_getreferencedentities entity_type entity_name_or_id reference_flag output_mark_id string_array number_of_strings ?search_type?
HyperMesh Tcl Query Command
Finds entities that are referenced by the specified entity. This includes collected references, data name references and attribute entity references. Each type of entity that is referenced by the specified input entity is returned in a list, and the found entities are placed on the specified mark for those entity types. See the list of supported entities for this command.
- entity_type
- The type of entity to query.
- entity_name_or_id
- The name or ID of the entity.
- reference_flag
- The type of referenced entities to find. Bit values are used and the value is
calculated as (Bit0 + 2*Bit1 + 4*Bit2).
- Bit0
- 0 - Do not consider collected entity references.
- Bit1
- 0 - Do not consider data name entity references.
- Bit2
- 0 - Do not consider attribute entity references.
- output_mark_id
- The ID of the mark to place the found referenced entities on.Valid values are 1 and 2.
- string_array
- Reserved for future use. Must be set to 0.
- number_of_strings
- search_type
- By default, HyperMesh searches for entities by name, and
if the name is not found, it then searches by ID. This option allows you to specify how
the search for an entity should be conducted. Valid values are:
- -byname - Search only by name.
- -byid - Search only by ID.
Examples
To get all entities referenced by component with ID 100 on mark 1 and highlight them on the screen:
foreach entity_type [hm_getreferencedentities comps 100 7 1 0 0 -byid] {
hm_highlightmark $entity_type 1 h
To get only collected entity references for component with ID 100 on mark 2:
hm_getreferencedentities comps 100 1 2 0 0 -byid
To get only data name entity references for component with ID 100 on mark 1:
hm_getreferencedentities comps 100 2 1 0 0 -byid
To get only attribute entity references for component with ID 100 on mark 1:
hm_getreferencedentities comps 100 4 1 0 0 -byid
# Handle error
}Version History
10-SA1-130
