hm_export
Exports data name values for entity hierarchy.
hm_export entitytype=<value> <select_type>=<selection> ?<option1>=<value1>? ?<option2>=<value2>? … ?<optionN>=<valueN>?
HyperMesh Tcl Query Command
Exports data name values for selected entity hierarchy in specified file format.
- entitytype=<value>
- The type of the root entity.
- <select_type>=<selection>
- id=<id>
- The ID of the root entity.
- mark=<mark_id>
- The ID of the mark containing the entities of root entity type.
- filepath=<value>
- The full path of the output file. File format is derived from file path extension. Supported formats are CSV and HTML.
- separator=<value>
- The separator character for CSV file.
- datanames={<value>}
- The list of data names.
- labels={<value>}
- The list of labels for each data name in the datanames list.
- level=<value>
- The type of the leaf entity to be queried for the hierarchy. Currently only valid value is components.
- numformat=<value>
- The numerical format.
- precision=<value>
- The precision of the exported numerical values.
- exportheader=<value>
- The flag to ignore column header export.
- consider_part_hierarchy=<value>
- The flag to switch export of assembly hierarchy and part hierarchy in case of include as root type. Reserved future use.
Examples
To export assembly hierarchy to HTML
file:
*createmark assembly 1 1
hm_export entitytype=assembly mark=1 filepath={C:/MassSummary.html} datanames={mass structuralmass nonstructuralmass} labels={{Total Mass} StructuralM NonstructuralM} level=component numformat=0 precision=4To export include hierarchy to CSV file with “;” as
separator:
hm_export entitytype=includefile id=1 filepath={C:/Inertia.csv} separator={\;} datanames={IXX IYY IZZ IXY IXZ IYZ} level=component numformat=2 precision=5To export include hierarchy to CSV file without column
headers:
hm_export entitytype=includefile id=1 filepath={C:/Inertia.csv} datanames={IXX IYY IZZ IXY IXZ IYZ} level=component numformat=2 precision=5 exportheader=0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
