hm_getfilletfacesfrommark
Returns the faces containing fillets with a radius inside a range, only considering specific faces.
hm_getfilletfacesfrommark entity_type mark_id radius_min radius_max
HyperMesh Tcl Query Command
- entity_type
- The type of entity to consider. Currently supported values are:
- mark_id
- The ID of the mark containing the entities to consider. Valid values are 1 and 2.
- radius_min
- The minimum radius value.
- radius_max
- The maximum radius value.
To get the faces with fillets with a radius between 5 and 15 only for surfaces in the assembly assem1:
*createmark assems 1 assem1
hm_getfilletfacesfrommark assems 1 5 15
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
9.0
