hm_writeviewcommands
Sets the state of writing certain view commands to the command file.
hm_writeviewcommands mode
HyperMesh Tcl Query Command
Sets the state of writing certain view commands to the command file. The following commands are affected:
- *rotateabout
- *view
- *view_restoreprevious
- *viewset
- *window
- mode
- 0 - Do not write these commands to the command file
To disable writing the view commands to the command file:
hm_writeviewcommands 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
