| ce_allowadjacent |
int |
0,1 |
Allow adjacent projection flag |
| ce_appliedmass |
double |
>=0.0 |
Applied mass value |
| ce_appliedmassdis |
int |
0,1,2,3 |
Applied mass distribution type: 0=div. by nodes 1=all
nodes 2=div. by area 3=unit area |
| ce_areaconstthickness |
double |
>=0.0 |
Constant thickness of area |
| ce_areastacksize |
int |
>=0 |
Density of area connector |
| ce_areathicknesstype |
int |
0,1,2,3 |
Thickness type of area connector: 0=(T1+T2)/2 1=shell
gap 2=mid-thickness 3=constant |
| ce_boltmaxdiameter |
double |
>=0.0 |
Max. diameter for bolt hole |
| ce_boltmindiameter |
double |
>=0.0 |
Min. diameter for bolt hole |
| ce_collectorid |
int |
>0 |
Comp ID of the connector entity |
| ce_collectorname |
string |
N/A |
Comp name of the connector entity |
| ce_configname |
string |
N/A |
FE config name of the realized connector |
| ce_configval |
int |
>=0 |
FE config value of the realized connector |
| ce_connectivity |
string |
Independent, FE connecivity dependent,use_shell_node, etc. |
Connector’s FE connectivity |
| ce_cords |
triple array |
N/A |
Coordinates of the connector |
| ce_density |
int |
>=0 |
Density value of line or seam |
| ce_diameter |
double |
>=0.0 |
FE diameter |
| ce_fesolver |
string |
Nastran, etc. |
FE solver name |
| ce_fetype |
int |
>=0 |
Realized FE type value defined in "feconfig.cfg"
file |
| ce_fetypename |
string |
N/A |
Realized FE type name defined in "feconfig.cfg"
file |
| ce_fevectorreverse |
int |
0,1 |
Vector reverse flag |
| ce_forcecollinear |
int |
0,1 |
Force collinear flag |
| ce_group |
unit array |
N/A |
Lists the connector and any grouped to it |
| ce_half_spacing |
int |
0,1 |
Half-spacing offset flag for seams or lines |
| ce_ijk |
triple |
N/A |
Connector’s projection vector |
| ce_layers |
int |
-,+,0 |
Connector’s defined thickness |
| ce_nonnormal |
int |
0,1 |
Allow non-normal projection flag |
| ce_numlinks |
int |
>0 |
Connector's number of current links |
| ce_offset |
double |
>=0.0 |
End offset value for a line |
| ce_positionstring |
string |
N/A |
A list containing the entity_type followed by the entity IDs selected to
create the connector. |
| ce_projection_info |
string |
N/A |
Projection information stored from last realization |
| ce_propertyid |
int |
>=0 |
FE property ID |
| ce_propertyscript |
string |
N/A |
Property script name and path |
| ce_remesh |
int |
0,1 |
1 for mesh-independent, 0 otherwise |
| ce_size |
double |
>0,0 |
Connector display size |
| ce_snaptonode |
int |
0,1 |
| ce_spacing |
double |
>0.0 |
Spacing value for lines or seams |
| ce_state |
string |
realized unrealized failed |
Connector entity state |
| ce_style |
string |
spot bolt app_mass seam area |
Connector style |
| ce_systems |
int |
0,1 |
FE build system flag |
| ce_trimsurfeachside |
int |
0,1 |
Trim surf each side flag for area |
| ce_tolerance |
double |
>=0.0 |
Tolerance value specified during FE realization |
| ce_type |
string |
node/point line seam area |
Connector entity type based on its creation |
| ce_usercontrol |
int |
0,1 |
User control flag |
