hm_getmidsurfcomp
Returns the name of the component in the model that contains middle surfaces and no other surfaces.
hm_getmidsurfcomp
HyperMesh Tcl Query Command
Returns the name of the component in the model that contains middle surfaces and no other surfaces. If such a component does not exist, or if there are more than one such components, the command returns "Middle Surface".
To get the middle surface component:
hm_getmidsurfcomp
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.1
