hm_getmodelchkvaluelevellimitcriteriaattribute
Returns model check values for level, limit, criteria and attributes.
hm_getmodelchkvaluelevellimitcriteriaattribute display_name
HyperMesh Tcl Query Command
This command returns model check values for level, limit, criteria and attributes for the specified check display name.
- display_name
- The display name of the check to query.
To get the attribute values for check "Material E is not defined":
hm_getmodelchkvaluelevellimitcriteriaattribute "Material E is not
defined"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0
