hm_ce_getfeprojfeatureelems
Returns the independent or dependent layer of feature elements.
hm_ce_getfeprojfeatureelems index layer
HyperMesh Tcl Query Command
Returns the independent or dependent layer of feature elements. Returns an empty string if there are no elements.
This is supported for: spot "acm" "style = 5" (feature elements are washer elements)
This should only be called from within a connector-registered property script. The projection data this relies upon is destroyed immediately after connector FE realization.
- index
- The index of interest in the array (corresponds to a weld).
- layer
- 0 - Return the dependent layer
To get the independent layer feature elements for index 5:
hm_ce_getfeprojfeatureelems 5 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.110
